As far as the twisting, read the manufacturers instructions for the "wire nuts". Some allow it and some don't.110.14 Electrical Connections.
(B) Splices. Conductors shall be spliced or joined with splicing devices identified for the use or by brazing, welding, or soldering with a fusible metal or alloy. Soldered splices shall first be spliced or joined so as to be mechanically and electrically secure without solder and then be soldered. All splices and joints and the free ends of conductors shall be covered with an insulation equivalent to that of the conductors or with an insulating device identified for the purpose.
Wire connectors or splicing means installed on conductors for direct burial shall be listed for such use.
Are you sure that some don't permit pretwisting? Can you cite a source? The only ones that I have ever seen said "pretwisting not necessary". That is not the same as saying "don't pretwist".As far as the twisting, read the manufacturers instructions for the "wire nuts". Some allow it and some don't.
I agree George. That's one of my pet peeves.Originally posted by georgestolz:
Somehow the 6" rule doesn't seem to apply to the ground in some minds.
I don't have my code here so I may not get this right but I thought the code required the free conductor length at the box to permit make up. That would mean that the length need not be that long after make up. In other words I would think that you could only inspect for the required free conductor length at rough in inspection but not on later inspection after the splices and terminations are made up. That does not mean that I think shortening them up is good practice I'm just not sure that it is a code violation.Originally posted by georgestolz:
I love how some guys won't go so far as to clip them off, but leave them too stinkin' short to do anything with in the future. A tad bit more wire goes a long way if you're going to eliminate or add a cable to the box someday. Somehow the 6" rule doesn't seem to apply to the ground in some minds.
