powerpete69
- Northeast, Ohio
- Professional Electrical Engineer
I see it in black and white.The subpanel is located in a separate structure.
That's where the grounding requirements come into play.
The city inspector passed my garage panel without a grounding electrode as long as the neutral and ground are separated. Perhaps its because its a 120V, 20 amp single pole breaker feeding it. Perhaps the small single feed breaker box is just a fancy "outlet" with some 15 amp breakers to allow for existing 14 gauge wire. Which it is.
As far as the hold down kit requirement for the backfed breaker, look at NEC 408.36d
Jap>
What is the purpose of this lock down kit? To keep the breaker from flying off in a short circuit situation due to massive magnetic force?
If that is the case, wouldn't all breakers need to be locked down?
