PatrickGoodyear
- Anchorage, AK
- Electrical Engineer
Larry, thank you for your reply. Your reply describes my initial thought. However, if I consider how a circuit breaker trips, the need for the fault current to return to the utility transformer, it seems like an EGC is needed back to the meter-main/transfomer neutral connection. NEC 250.32(B)(1) requires the EGC, and a re-grounded neutral is only allowed in installations prior to 2008 NEC.
