B
bthielen
Guest
Had a situation arise the other day. A friend is wiring a new 20A branch circuit in his garage and decided to use 10ga. wire from the circuit breaker to the first receptacle then reduce to 12ga for the rest of the circuit. He had it in his mind that he was protecting against a voltage drop, although he didn't calculate it and it really wasn't that far. The inspector failed it and had him reduce the 10ga. down to 12ga. My friend made the changes requested to avoid issue but afterwards asked the inspector for an explanation, stating that he didn't feel this was an actual code violation. It turns out that the inspector just preferred to protect against a future homeowner seeing the 10ga. wire, thinking it would be okay, and changing the circuit breaker to a 30A for one reason or another. The garage will be finished and the wiring will be hidden in the walls.
It is agreed that the change was for the better but is it the responsibility of the inspector to force a change he/she believes is for the best even though it may not violate the accepted codes?
Would like some opinions.
Thanks,
Bob
Thanks,
Bob
