al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: AFCI confusion
Thank you, Charlie B. I just figured out (finally remembered?) that a resistor is conductive like a metal, even though it is in the same periodic table column as silicon. A resistor's conductivity increases with temp fall. Therefore it isn't correct for me to assert that it is a semiconductor (whose conductivity increases with temp rise). Thankyou for helping, spurring me to this. A variable resistor used as a rheostat won't qualify for the definition of an electron device.
It is interesting to note that the IEEE Standard Dictionary Of Electrical and Electronic Terms lists:
Proven As Stated.
Noting:Electronic. Of, or pertaining to, devices, circuits, or systems utilizing electron devices. Examples: Electronic control, electronic equipment, electronic instrument, and electronic circuit. See: electron device
Electron Device. A device in which conduction is principally by electrons moving through a vacuum, gas, or semiconductor.
The altering of the sine wave, to me, is not the salient point, but rather:Originally posted by Charlie B.: Once you alter the nature of a sine wave, by performing any switching on a ?part cycle on, part cycle off? basis, then you are definitely into electronics.
Clearly, then: </font>Electron Device. A device in which conduction is principally by electrons moving through a vacuum, gas, or semiconductor.
- <font size="2" face="Verdana, Helvetica, sans-serif">The comodity 125 V 600 W incandescant only semiconductor dimmer (black in, black out) that costs $7.00 at the corner hardware store has a semiconductor that is the principal conductor, while the dimmer acts as a dimmer.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The semiconductor based dimmer switch uses electron devices for electronic purpose,</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">A dimmer switch meets the definition of ?utilization equipment,? and</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">A box that houses a dimmer switch meets the definition of ?outlet.?</font>
Proven As Stated.
