Re: 4/0 cable into the back of a 3 1/2 inch deep panel
I assumed there was an advantage because this post indicates entering the back is common. I can see the reason if no room to do anything else, but in new construction when you could enter from the top or the back, why would you enter the back, in a basement? I could also see that in the case where the meter is directly behind the panel in a garage you would enter from the back. In my basement, the slope of the ground means the entrance into the basement is not buried. It seems like it could have entered the basement through the wood instead of the block, which would be easier, so is there some benefit to the extra trouble to drill through the concrete block to enter the panel in the back?
