jimwalker
- TAMPA FLORIDA
Got my hands on a roll of triplex aluminum with steel messanger #2.Markings are gone so not sure if it can be ran in pvc underground.Willing to add neutral because i know it needs a ground.Run will be 100 feet.Have 100 amp sub panel with main 100 amp breaker factory installed.Is there anything wrong in using the bare steel as the ground and adding a #2 neutral ? What is the letters to most triplex wires ? It was used for temporary service, part underground, part overhead.It will feed a shed that i need at max 60 amps.Trying to use what i already own.
