I don't see an issue.In side a chiller plant
Those should work. I believe it's a closed-cell product. I think it's primary purpose was for vibration dampening.
I do not see any issue with this at all. Does this chiller yard have cooling towers? If so, I would highly recommend using schedule 80 PVC or PVC coated rigid because that EMT will not last long in that environment.Can u support steel EMT to stainless steel unistrut? Or will it cause a problem with the metals touching.?
