Re: Service Neutral
A generator winding is the same as a transformer secondary. The transformer primary is equal to an exciter in a generator. Both provide a magnetic field and relative motion.
When a premises wiring system is supplied by a transformer, and only connected by magnetic coupling, no direct electrical connection, the premises wiring system is an AC system without external connections.
When a premises wiring system is supplied by a generator, and not electrically connected to another source, it is an AC system without external connections.
The main concern when AC was adopted for domestic power, was the fear of a winding to winding fault.
All transformers will fail, the first failure is usually a high to low fault, that eventually develops into a ground fault.
When the premises wiring system sees this fault, the first thing is the, on line, appliances get fried, lamps blow out and clear the circuit. When the active side clears, the neutral side is still a complete circuit to earth. There is nothing to clear this fault except the primary fusing.
A transfer switch must electrically isolate the premises system to be considered a separate system.
The load current on the equipment ground theory is a fabricated hypothesis to explain why the neutral should be switched.
Routing equipment ground conductors to make all connections dead ended will correct any objectionable current flow.
I am challenged to prove my statements, I will return the same request. Prove my statements are untrue and I will post a retraction.
