Midwest Electric Services
New member
I have installed the Maestro dimmer with a so called matching CFL bulb when i turn the power back on the dimmer cycles on and off. I was told to replace one of the bulbs with an incandescent bulb and when i did it worked!! Now to keep all the bulbs the same i think i would have to put a resistor in parallel to trick the dimmer that their is a bigger load on it. Any ideas would be great!!!!
