This isn't always true.No. No. No!!!!!!
250.30Originally posted by Leitmotif:
OK so when do you tie the neut and ground together in a sub panel??
Check with the navy; they have plenty of them.Originally posted by electricmanscott:
I just read 250.30 and 250.32 B and I did not see anyhing about a "sub panel".
In my Navy days, I only had to deal with "target panels."Originally posted by LarryFine:Check with the navy; they have plenty of them.
In Washington, you can't ever tie them together in a sub panel. Since he signed as Seattle, WA, I thought I'd point that out. Its a state WAC rule and not an NEC one.Originally posted by Leitmotif:
Could you give me the rule number? I want to look that one up. If the WAC actually calls it a "sub-panel," then Tom will have to stop saying that that phrase doesn't have any meaning.Originally posted by suemarkp:Its a state WAC rule and not an NEC one.
Sure, Tom knows what it means. He is just channeling "Bennie" again.Originally posted by suemarkp:. . . but I think we all know what he means.
You're right. We're hoarding all the secrets, belittling the folks just starting out, and leaving them idiots out in the cold.Originally posted by aa0qm:
As usual it is full of insecure so-called pro's simply trying to make all questions look stupid and even make each other look stupid. You know who you are. There are exceptions, of course, like Suemarkdp (or something like that). Bonding/grounding is one of the most misunderstood subjects in the NEC. Even the inspectors in our area can't agree on everything regarding this subject.
