Re: as-builts, shop drawings what software?
I have been producing
As-Builts, or the more preferred term
"Record Drawings", via CAD packages, for many, many, many-many-many years!
In fact, the last "Professional" Drawing (Plan) I drew Mechanically (by hand...i.e: Pencils, T-Square, Scales, Triangles and Stencil Kits), was in like 1994! And that was because the project was small, and someone already had an "E" size templated base plan copy (Blackline copy) - so no setup needed!
If you (the original poster of this topic) plan to go the CAD route for Record Drawings, the first issue to overcome will be getting a usable base plan... from someone...sometime before you reach retirement age!
Architects are the ones I get base plans + others from.
(base plan = the "Raw" layout per floors - with only the walls shown).
The Base Plan(s) will normally be OK - provided they saved it as a compatible file / version type!
Since many Architectural firms use Microstation, they usually send me drawing files with some type of an issue (sent as a Microstation file format, etc.). A few faxes, e-mail messages or just Telephone calls, and things get resolved.
The real fun is involved with Elevations, or layered drawings showing the RCP (Reflected Ceiling Plan), Furniture Layers, and similar "A" Sheet stuff.
From their 3-D Rendering of the drawings, each drawing file ends up with about 150 layers!
Other fun stuff includes non-continuous lines, embedded Xrefs, unfindable shape fonts, missing Xref'ed files, and the most annoying: Scaling Issues (Drawn dimensions are smaller/bigger than the actual building's dimensions!).
It takes quite a lot of learning, when making the jump from Mechanical / Hard-Copy type drafting, to any CAD Package. Took me for ever! But once you do grasp it, and get the "feel" for it, you will never go back to Hard-Copy work again!
I know you weren't planning to become a full-fledged CAD Operator, only need to mark up for As-Builts, but nevertheless, give it a try sometime.
As per the markups on this project, how about submitting a cleanly marked up set of "E" sheets to the Electrical Engineer / Architect - and let them do the CAD work?
If you can do this, great - other option would be to have someone who is a CAD Drafter, do the CAD work + save marked up drawing files to CD-Rs, then submit as required.
I perform this work for many ECs and a few GCs.
Depending on the complexity of the job, I will charge between $250 and $1,000.
A little history / comments:
Have seen many times where Contract Documents request As-Builts compiled in and submitted as, a certain CAD file format. The most common being AutoCAD (many still request AutoCAD R14 version drawing file compatible saves).
Seen this in Project Manuals (in Generals and Division 16), along with the General Notes and Specific Notes of Plan Sets.
A few have included Adobe Acrobat ".PDF" format as an alternate submission - others have requested .PDFs as an additional save type! (save drawings as ".DWG" AND ".PDF"!)
Have many, many, many-many-many As-Built sets floating around Southern California - saved as ".DWG" and Plotted (AKA "Printed").
Most are inside of Bank Branches, Loan Centers, Fic. Corporate Campuses and Admin Centers, but maybe 20% (probably a good 120 sets) exist outside of the Banking Realm, in places like Television Center (Hollywood), Dentists' Offices, Machine Shops, and other Commercial / Industrial locations.
Contact me if you have any questions / comments regarding CAD Packages, via either P.M. or E-mail.
My address is:
setelectric at pacbell dot net
FYI: Here's some other stuff you may do with a CAD Package (click on a link to view):
http://electrical-contractor.net/ubb/Forum15/HTML/000078.html
http://electrical-contractor.net/ubb/Forum15/HTML/000067.html
http://electrical-contractor.net/ubb/Forum15/HTML/000066.html
http://electrical-contractor.net/ubb/Forum15/HTML/000065.html
http://electrical-contractor.net/ubb/Forum15/HTML/000072.html
http://electrical-contractor.net/ubb/Forum15/HTML/000070.html
http://electrical-contractor.net/ubb/Forum15/HTML/000054.html
http://electrical-contractor.net/ubb/Forum15/HTML/000053.html
http://electrical-contractor.net/ubb/Forum15/HTML/000052.html
http://electrical-contractor.net/ubb/Forum15/HTML/000051.html
http://electrical-contractor.net/ubb/Forum15/HTML/000050.html
http://electrical-contractor.net/ubb/Forum15/HTML/000049.html
Scott35
