Re: AMP READING ON GROUND
I can elaborate but it may get lengthy.
First of all this was a 200 amp rewire job.
I will try to shorten this somewhat.
When he installed the wires in the weather head I was told by another electrician that he used a wrong wire for the nuetral to the meter base, it has a yellow stripe I was told was against code. When he installed the roof boot, he laid it on top of shingles instead of lacing shingles over it to keep it from leaking.
He installed a brand new meter base disconnect box on the outside of my house, I was going to run power to my garage from there, I asked what kind of breaker goes in that box, he told me and I bought one and it wouldn't`t snap in. I asked my buddy the electrician and he said he would install it, when he tried to install it he had trouble also so he got his trusty screwdriver out and started bending the plastic breaker holders and broke them on one side he said he would call factory to see what the problem was so about 3 days later I came home from work and found a breaker in the box. The following weekend I thought this would be a good time to run power to my garage, I did and when it was time to hook wire to breaker he installed it almost fell out when I removed breaker cover, I checked and he had broken the plastic clips on that one also.
I only wanted 12-2 wire used in my house and he knew that from the start but when I drop by after work one evening I found 14-2 all over the place, I jumped him about it and he said 12-2 is just overkill, that isn`t the point I wanted 12-2. I measured and I added for pigtails in boxes and I came up with less than one 250 foot roll of 12-2 used in my 2 story house with a basement.
Getting to the breaker box which is brand new and when they mounted it I measured it and it is mounted 4 inches from the wall to the outside cover at the top and 8-1/2 in away from the wall at the bottom. I already said is not bonded to the water system, it looks like a 6th grader installed this, the labels on the door to identify what breaker is for what you can`t hardly read, When the breaker in the kitchen kicks I go to set it and it is not kicked but the one that says dining room is. Things are scribbled out with magic marker pencil and ink pen, things are not what they say they are. For instance I had my microwave plugged on a 15 amp circuit and I had a lot of trouble when starting with breaker kicking but if I made sure my kitchen light and the porch light was off microwave wouldn`t kick breaker as much of the time.
He installed one 20 amp gfci circuit with 2 outlets over my counter top which is 14 feet long, he didn`t install any outlets on or around my island. I know this is an older home with plaster walls but every hole he cut in the walls is botched, I can get a finger or two in along the side of most of the boxes. The boxes used were old works boxes, I have had some of the pull out when unplugging something.
He installed new outlets in several rooms and the is 3 places that when cutting hole, I don`t know what he used but plaster is knocks off the wall for 22 inches on one outlet and 18 inches on the other two. In one bedroom which is wallpaper over plaster it looks like he make the hole with a sledge hammer, the paper is sticking out around the plate. Several places plaster is so damaged I can stick my finger or finger in along side of the plates, I jumped him about this and the wallpaper damage he said there was nothing he could do, he wasn`t a capenter. I have worked with plaster in the past and I know holes can be cut in it if you take your time.
I had ceiling light fixtures he took down to run new wire to and when reinstalling light fixture he didn`t even cover original holes light was installed in. There was no ceiling light fixture in the living room so I wanted box and wire and fan support installed so I could install one later, when I was ready to install a fan/light fixture, there was nothing on one side of their fan box to mount to, I had to completely redo the fan support. When they cut the hole in the tile for the box they over cut it, I thought the fan would hide the hole but after it was installed I can get 4 fingers along side through the tile. When they cut holes for boxes in my paneling, it almost looks like they used a chain saw, paneling is splintered and there is chatter marks where they let the saw get away from them and run down my baseboard and across the paneling. Right now I can sit on my couch and look at 3 outlets on my north wall and these are new installs and one is tilted to the left, one to the right and one is at a different height and I haven`t described the other 3 walls yet anyway they are the same way. On my east wall they drilled holes through every black line in my paneling, I assume they were stud finding. They used 16 penny nails in 3 other rooms for thet purpose and even left the nails in the wall in some cases.
My dining room had one two gang box, one switch for the light and one for the porch light, I wanted a 3 way switch for the light installed, this was a new installed switch and they mounted it5 ft. 9 in. from the floor and with the plaster damage and the wall paper damage feeling for this switch in the dark when sliding my hand up the wall I am always catching the ripped wallpaper and it is really looking bad now because of this unusual height.
My breaker box is in the basement the first thing they did was drill a 2-1/4 inch hole through 31 of my 2x8 floor joist and by the time he gets to the end he has only one 14-2 wire run through one 2-1/4 in hole I am no structural engineer but I did talk to one and he said I won`t have problem today but I will if something isn`t done soon to re enforce these floor joists.
I have 3 knock out holes in my breaker box left open. I was told by the other electrician that the 4/0 cable going into my breaker box has a romex clamp instead of a cable clamp which he said is wrong.
There is a 10-3 wire un to my central air unit and it has 5 places in the ouside jacket ripped, I know the inside isn`t damaged but I don`t was something damaged when I have something installed ne. I have no GFCI in the basement, I have no dedicated circuits in the basement for sump pump the sump pump is plugged into a 20 amp circuit with a 15 amp outlet. I have several problems like that 14-2 run to 20 amp breaker and 12-2 run to 15 amp breaker and the switch to my furnace is a 15 amp switch on a 12-2 wire, I know this will probably never cause a problem but I know it is not right.
I don`t like a juction box he run for my living room, he run a 12-2 homerun and has nine 14-2 romex connected to it I am concerned about boxfill. I have some juction boxes without covers. He has no seperate light circuits, from what I can tell they are just conected to each room, I would like them seperate to some extent, incase I kick a breaker I don`t have to walk around in the dark.
He has romex dangling in my basement, it wouldn`t of been too hard to put a few staples in to support it.
I guess I better wind this down, I could go on yet but I bet you are sorry you asked me to elaborate. It does help to vent some. after getting a job like this. I took pictures of this mess I have about a hundred pictures from the top to the bottom. This job started out to be kind of a buddy/buddy thing and then when he hands me a bill a month after he said he would be done and $2000.00 more than he said it would be, I want the job done right. Thanks George for listening.
Mike
