Cutting pipe with the Sawzall
peter
San Diego
To get a proper 90* cvt, yov can vse a plvmber's tool viz. the pipe cvtter. Vnfortvnate it leaves a sharp bvrr on the pipe. However there is a tool designed to combat this. Perhaps cvt it halfway with the pipe cvtter and then finish with the bandsaw.
~Peter
templdl
Wisconsin
~Peter
Thank you Peter. Finally there is someone who types like I do.
get you a 18v dewalt bandsaw with 18t blade, you can cut 1/2'' -2'' pipe and 1-5/8'' unitrut with one hand
hands down the best tool for cutting,you will never need a sawzall again
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
~Peter
Someone needs to "buy a vowel" or go to "U" tube and borrow one!:D
PetrosA
U is the new V, actually. W is so called, because it's two of these VV. They did that because V was also V (U), like here:
IN HONOREM PRINCIPIS APOST PAVLVS V BVRGHESIVS ROMANVS PONT MAX AN MDCXII PONT VII
(In honour of the Prince of Apostles, Paul V Borghese, a Roman, Supreme Pontiff, in the year 1612, the seventh of his pontificate)
Hopefully that makes it all clear as mud :)
Sierrasparky
USA
Electrician ,contractor
Alrighty then
peter
San Diego
Cat jumped on my outdoorcomputer and destroyed the "u" key soI just used the "v" key which is close. Sorry.
The sawzall is a two handled tool. It is a demolition tool and is not very accurate.
Vises are not allowed on construction sites. I don't know why that is so nor do I wish it were so. Onetime we ended up working in a classroom which happened to be a shop classroom with a vise on every table. My compatriot went into the usual contortions to saw a piece of pipe.
~Peter
I got a Harbor Freight bandsaw. It costs about $80 instead of +$250. The first one I got worked once and permanently died. I e-mailed them and they said "Put it on the porh." I did and they soon replaced it.
PetrosA
~Peter
I think in the hands of a carpenter, you'd be right. In the hands of an electrician or plumber, it can be an accurate tool. I have a Hatchet (unfortunately no longer available) with which I've been cutting boxes into kitchen cabinets for six years now. It takes some practice and works best with a scroll blade, but it's every bit as useful as a jigsaw. I did finally get a Fein Multimaster tool, but it creates a lot more dust and requires hearing protection when used in a cabinet.
I think a band saw for 1/2" & 3/4" EMT is overkill, but if it's there, go for it. I'd still prefer my Hatchet as it's a lot lighter and easier to use. Larger or heavier conduit, then yeah, a band saw is the way to go.
ceknight
Why do most of the people who said they used tubing cutters only score it then break it?.
That was the manufacturer's instruction for use with mine. Yeah, I cheated and read them. ;)
Re the OP, I haven't seen anyone suggest getting a plate vise yet to hold the sticks -- if you're cutting them on the ground. It'll stabilize the tubing just fine, assuming (unlike me) you remember to get it out of the van.
