Has anyone experienced field performance or safety problems with transformers connected wye-wye? I plan to specify an outdoor, three-phase, pad-mounted transformer rated 75kva, 25/14kv-120/208v with both neutrals bonded and grounded to a ground ring around the slab. I usually specify only delta-wye connections, but the nearby transformers are rated wye-wye so I assumed that they were common practice in that area. I've heard horror stories about wye-wye connections, but I'm not sure if they were based on fact or fiction. Excuse my slow response to any questions you may ask, but I will be out of town for a week. Thanks
