Pretty typical around my parts. Although it’s an eye sore and in some scenarios is “subject to physical damage”.So I'm in Vermont and a friend of mine is building a barn and I noticed that his service has xhhw-2 wire run on the outside of the wall. I've never seen that before. We would not do this in Colorado. Is this normal around the country?
Same here but what I have seen is older stuff. The newer services are in conduit of SE cable but sleeved.I see it occasionally, but it hasn't caught on here yet. PVC more often than it used to be.
looks much better than PVC IMO
I agree, overall SE in opinion looks neater and blends in better.SE cable super common surface mounted around here. Personally I think it looks totally fine when run neatly, looks much better than PVC IMO
Here in Florida a lot of homes built in the 50's and 60's had SE cable strapped to the block and used an SE weatherhead. It's not common today, but most AHJ's will still allow you to use it for repairs.You guys run uf exposed on outside of building? Never see se cable exposed like that. Only seen if once!
What right does the authority having jurisdiction have to turn it down. It is compliant. Personally I would never use it but it's done alot in the NE. I remember Bob Badger saying he ripped out a job(maybe his own home) that had pvc and he install se cable as the riser. To each his ownHere in Florida a lot of homes built in the 50's and 60's had SE cable strapped to the block and used an SE weatherhead. It's not common today, but most AHJ's will still allow you to use it for repairs.
Yup. I would probably do the same thing, rip down the PVC and put up SE cable, I hate PVC above groundWhat right does the authority having jurisdiction have to turn it down. It is compliant. Personally I would never use it but it's done alot in the NE. I remember Bob Badger saying he ripped out a job(maybe his own home) that had pvc and he install se cable as the riser. To each his own
The right they have I guess is that they have the authority to supersede the NEC if they are more stringent. In Orlando, for example, your (2) small appliance circuits can't have more than (2) duplex receptacles on them. (That's how it was when I left there in '98) In 2008, Oklahoma City's Building Dept. requires you to use the colors black, red, blue for respective phases on 120/208 systems. So we had to start buying MC that was red, white and green and blue, white and green.What right does the authority having jurisdiction have to turn it down. It is compliant. Personally I would never use it but it's done alot in the NE. I remember Bob Badger saying he ripped out a job(maybe his own home) that had pvc and he install se cable as the riser. To each his own
unless it’s in your state electrical amendment they cantThe right they have I guess is that they have the authority to supersede the NEC if they are more stringent. In Orlando, for example, your (2) small appliance circuits can't have more than (2) duplex receptacles on them. (That's how it was when I left there in '98) In 2008, Oklahoma City's Building Dept. requires you to use the colors black, red, blue for respective phases on 120/208 systems. So we had to start buying MC that was red, white and green and blue, white and green.
