fracas666
- Northern New Jersey
On a job that I was working on someone before me roughed in a four gang device box using one four wire and one two wire metallic cable. The four devices that I installed in the box were single pole switches. I was told to use the white wire of the four wire cable as the power feed to each switch. The black, red, and blue of the four wire cable and the black of the two wire cable as the switch legs. The white wire of the two wire cable was capped off. The other end of both of the cables were in the same splice box which also contained the feed and the cables to the four loads. Although there may be better ways of terminating and splicing these cables, is this installation wrong? If so what is wrong with it?
Ron
Ron
