Re: whirlpool connection
I used to install a GFCI recep. in a readily accessible location in the bathroom with the hydro tub. Then run the load side to the motor location. I would mount a box on a 2x4 with about a 3' romex tail so I could easily access the outlet if I needed to. I would place the outlet just inside the access hole. Now that I'm an inspector , if I can't check the tub outlet ,I can't pass the job. Hope this helps. Ron
