Our Staduim is a 208/120 Y system. The other day at the football game a video trailor plugged into a dedicated 20amp 120volt circuit. They could not use the plug because the voltage would drop to 105 volts and it was too low for them. I went over there today to test it. I tested the voltage and it was 118.5 volts without a load. I put a load of 16amps on it and it dropped to 108volts. Is this normal? If not, any thoughts on what the problem could be and how to fix it? Thank you
