Re: Voltage Drop-Parallel Conductors
Originally posted by lizzie14: Do you use the resistance for the parallel wire size??
If by that phrase you mean taking the resistance of a single conductor, dividing it by the number of parallel conductors, and using that total resistance value in the VD calculation, the answer is ?yes.? On the other hand, if you mean looking up in the tables to find out what conductor type has the same cross sectional area as the combined area of the parallel conductors, then looking up the resistance value for that conductor, then the answer is ?no.?
