Re: using only 2 phases of 3 phase system??
It?s been a while since I?ve seen it, but it was fairly common at one time to use this arrangement where the total single-phase load was very large compared to the three-phase load. (It used to be a common test question, in fact)
Essentially the system is operating in an ?open-delta? with the single-phase load fed from the larger transformer (center ? tapped for 120/240). A much smaller transformer was then used to accommodate the smaller three-phase load (240V). There was a modest economic benefit since the high-leg service conductor doesn?t have to be as large as the other two legs and 240V conductors would (in theory) be smaller than the alternative 208V. BTW 110.15 and 230.56 would apply here.
Obviously, this would only apply if the three-phase load is 240V.
Now days its usually pretty sound to simply use a 208-120V three-phase system.
