inspector_guy
When I inspect a house I use a little tester that I plug into all of the outlets. My tster has the button on top to push in to see if the GFCI's will work. 90% of the homes I inspect have no GFCI's anywhere (even some of those built in the last few years have no GFCI's or GFCI breakers). I have tested some GFCI's that do not trip when I push the button, these are on remodeled homes with the old type two wire romex- no ground wire.
How do I know if these breakers will really work or not? I have tested a few GFCI's on grounded systems where the GFCI did not trip, just the 'test' and 'reset' buttons worked- and other GFCI's on grounded systems did trip with a push of the button on the tester. Forgive me for not using the correct terminology, I've gotten hung up in my own slang. Any idea's or comments are appreciated in advance. Takk, Joe.
