kaiser
- los angeles, ca. USA
Hello, everyone
I have a question, or need advice.
I am doing a rewire for a residential kitchen and the owners do not want the backsplash of the countertops to have any receptacles cut in through the tile backsplash. They want undercabinet power strips. Which is fine but I've yet to find a good product with enough outlets per foot and I'd prefer the strips to be GFCI so I don't need to put GFCI breakers in the panel (for convenience if tripped) .
Do any of you know of a manufacturer of such a beast?
I'm in Los Angeles so logistically that may help.
Besides the GFI built in, having four or six outlets per foot or eighteen inches would make me happy. There are only two upper cabinets and each is 36 inches wide. I've got each side on their own dedicated 20 amp circuit and the height requirements for receptacles on a backsplash is still within code if the strips are mounted under the cabinets.
Let me add something for background info. You're probably wondering why I want so many outlets per strip? Well the homeowner has a thing about having plenty of outlets. I rewired and brought to code this house (ca 1954 ish) and every receptacle in every room they wanted two-gang boxes with two duplex 20 amp receptacles. So, that gives you an idea of why I need plenty or outlets on a strip.
Maybe a computer server rack power strip manufacturer as a source? Any help would be so great and appreciated.
Thanks in advance.
Thanks in advance.
