RatherBeFishin
- New York
- Electrical apprentice
Is there anywhere in the code that illicitly says it’s acceptable to use a larger switch than ckt rating on a circuit? Ex. Using 20 amp toggle switches throughout a house on 15 amp lighting ckts
It’s done pretty commonly with disconnect switches being rated for up to 60 amps being used on a 20 amp circuit let’s say
I know to never go the other way of course with let’s say 15 switches than on a 20 amp rated ckt although some argue it’s fine, but does anyone have a reason or code section that says to not use larger switches than circuit rating? As far as I know it’s just like using larger wire than needed on a ckt but could be wrong
