Whern you guys set switchgear on slab how do you secure it? anchors? I think I also heard something about strut in the poured slab? Maybe for leveling??Thanks
For large switchgear a pin and sleeve anchor in each corner when we're actually even bothering to secure them to the slab. We've also set steel rails before the slab is poured for the switchgear to sit on (also common for generators). Those get drilled, tapped, and bolted to the steel.
