We have a selector switch and a E-stop push button station. Both devices are mounted to an Enclosure.
The contractor chose to wire the switch and the E-stop by installing pigtails from each device. Wiring from the main control panel was installed to the Enclosure. Is there anything in the Code that requires to have a terminal strip in the box to make the connections? can simple wire nuts be used instead? or is it more like preference?
Thanks for your thoughts.
