I have a Siemans G2430MB1150 load center. House built in mid 90's. My understanding is this panel can have up to 30 circuits. My panel is currently full with no tandem breakers. I'd like to add two tandems to make room for a 50amp breaker to be used with a hot tub. The diagram on the inside of the panel makes it look like I can add tandems to the lower 3 slots on each bus, however when I removed the breakers in those last three slots the stabs were not notched to accept the tandem breakers. Can I simply add the NON CTL tandems breaker to this location that according to the diagram is supposed to accept tandem breakers?
