This is usually a ?local practice? issue.
The general subject is discussed in NFPA 820. While methane is definitely flammable, it diffuses very quickly and, in fact, is generated in relatively low volumes for residential applications. Hydrogen Sulfide (the ?smelly? stuff) is also ignitable but has a relatively narrow ignition range and is also generated in fairly low volumes. The typical residential application is usually considered ?unclassified? by most jurisdictions.
Larger applications for major waste waster treatment facilities usually have a mix of Division 1 and 2.
