Re: RURAL LOCATION REQUIRING WELL PUMPS
The well digger indicated to me that at least in the county where this dwelling unit resides they drill the well and as they drill the well using special bits of some kind which I will watch as the well is dug, the hole is encased as they dig.
The pump motor is located(at least in this county) always 40 feet above the water depth. The deeper the well in most cases the cleaner the water. The encasement, or water pipe highway from the pump does have a check valve to eliminate or minimize preasure loss when the pump is not running.
Someone mentioned a grd electrode would be required for this pump and that no disconnect would be required and I am assuming by reading parts of article 430 that the preasure switch (controller) bay be acting as required disconnect in this case.
I will read more on article 250 and 430 for disconnect and grd electrode information to try and clear up any confusion that I may be having. Thank you all for responding, and if anyone has any further comments on this they most certainly will be welcomed.
Thank you
