Rotary Timer
tshephard
I need to find some rotary, spring/"clock" timers (for hot tub, infra-red lamps) that do not use the device mounting screws for cover plates; ie, can use standard light switch covers.
Customer has brass plates throughout home, and was ready to drill into Rhodes timers to mount covers!
All timers I can find use mounting holes to also mount their own covers, and only have the 2 holes. What I need would have 2 holes for mounting, and 2 for cover "inside" others like a standard switch.
Tub would need 20A/1 HP, lamps would be OK at 5A.
Thanks for help!
[ June 03, 2005, 07:19 AM: Message edited by: tshephard ]
mdshunk
Right here.
Re: Rotary Timer
Uh, huh. I agree with the Intermatic. They can use a regular toggle cover or use a decora cover, either one. They come with a number plate when you're using a toggle cover.
