jayzbond007
- Planet Earth
Hello,
I have a job where the solar array is mounted on the roof, the USE-2 is running under the array and want to transition it into THWN-2 in emt conduit. Since this AHJ requires a rooftop DC disconnect, can I make the transition in there or does it need to be in a junction box first? Is there a specific code in the NEC that says specific enclosure used for transitioning?
Thanks!
Thanks!
