rewiniding an oil immersed motor stator
a.bisnath
Electrical worker
working on a conveyer drum motor,where the motor is inside the cylindrical drum itself, the motor and gearbox are in constant contact with splashing gear oil.The stator has a shorted coil and has to be rewound,are there any special considerations to be aware of when rewinding a motor that is in constant contact with a petroleum based oil?
GeorgeB
ElectroHydraulics engineer (retired)
Greenville SC
Retired
I used to support Vickers hydraulic systems, and they have an "IMP" integrated motor pump which pumps petroleum hydraulic fluid through the motor. I just checked the service manual for rewinding procedure, and it says
10. Reline stator slots with no less than Class H insulators.
11. Use a standard rewind procedure with Class H insulation.
If you want to PM your email address, I'll send the entire document or, your choice, the 2 pages extracted ... 2 pages of 18 cover rewinding.
