So, normally if you have a detached garage you run the a sub-feed through the existing house to a stubout on the otherside where the garage would be located and run power to it from the stubout. But, if there is a what can be condsiered living space in the second structure (ie...apartment or office above the garage, or if the second structure is an apartment) that the service feed cannot run through the main structure/house. is this correct? Or can we run the sub-feed as originally outlined above (through the house to a stubout and power the second building from the stubout)? I had this on a continuing education class and I wanted to make sure I didn't misunderstand the rule.
