Hi guys,
I am a facility electrician that also does the typical smaller electrical construction projects in an office building and I have recieved a work order project to put together a quote to replace 55 single pole switches with motion sensors. Keep in mind that Lock Out Tag Out plays a huge factor here and the electrical panels are not labelled well. How Long should it take to replace these while using lock out tag out? Should I quote the remodel column under the Durand Labor Units? All advice will be taken. Thanks all.
