That happens? The what is done with the wire in the panel? What about the other end of the ckt.? How is it located in the future? Thanks.
The NEC does not 'show' you how to do that.
Below is one way. Label the wires.
Change the directory label for the circuit to SPARE, isolate (wirenut) the circuit conductors and install blank cover at the outlet.
Edit to add: Pull wire if in any type of in-floor raceway.
372.13 Discontinued Outlets. When an outlet is abandoned,
discontinued, or removed, the sections of circuit
conductors supplying the outlet shall be removed from the
raceway. No splices or reinsulated conductors, such as
would be the case of abandoned outlets on loop wiring,
shall be allowed in raceways.
Now who decides if it is discontinued? I say the property owner.
