Re: Quality
... the local cable company almost immediately cuts off the hex crimped ones at the first trouble call they get before any testing has been done...
That's because they use SNS's exclusively and any other connector means it wasn't installed by them. If it wasn't installed by them they have found that 99.9% of the time there is going to be a problem with it, so to save a lot of time they just replace the connectors first as a matter of course. They probably don't replace your SNS's because there is no indication they weren't theirs. There is no reason to believe that SNS's can't be improperly installed either.
There is no difference in performance between properly installed connectors. Apparently Comcast has standardized on SNS's, nothing wrong with that nor is there anything wrong with hex crimps which are used by many other cable companies. I would say that when in Rome do as the Roman's do and use the same materials as Comcast, either that or leave the terminations up to them, especially if it is going to cause problems.
There are all kinds of cable prep and stripper tools out there, some work, some don't strip the cable properly and others don't work at all.
When I was doing master antenna work and later work for the cable companies back in the 80's I prepared cable for connectors with a Miller #101 wire stripper. Other guys prefered a sheet rock knife, there were no fancy coax strippers back then. Ring the jacket and pull it off, score the dielectric, twist and pull it off. Fold the braid back over the jacket and cut it to length with dykes. Do this about 1,000,000 times and you know exactly where to cut for every cable and connector combination you use.
Each cable and connector combination will have differing stripping dimensions and other requirements such as folding the braid back over the jacket under the connector crimp. These will be found in the connector manufacturer's literature.
I don't do nearly as much of this as I used to but I still have been using my trusty Miller stripper and dykes. I recently picked up a Harris coax stripper just to see how well it worked. Well, after spending about 20 minutes taking it apart, modifying one blade on a bench grinder so that it wouldn't cut so deep then putting it back together I finally got it so that it will produce an acceptable strip. It still needs to be adjusted with the allen wrench when I use it on different manufacturers cables. Dunno, I still can do it faster with my Millers.
Next chance I get I'm going to try a stripper from Cable Prep. I have always used their crimpers and other prep tools for solid sheathed cables (hardline). They only make tools for the CATV industry so hopefully theirs will do what it is supposed to.
My advice to you is to see what the Comcast guys use, works for them should work for you.
-Hal
