sparkyrick
- Appleton, Wi
I had a service call today to trouble shoot some puck lights, 13 of 14 were out. Not knowing if one of the two power supplies was bad, I checked the output voltage first. First unknown supply: 0V, second known working supply: 0V :rant: I tried AC, then DC, still nothing. I looked at the labeling on the power supply, input voltage 120V, 60Hz AC, output voltage 12V, 20KHz AC. Apparently my Fluke 376 can't measure a 20KHz power supply output. This is the second time I've run across this. How does one test these power supply outputs with a meter?
