this subject has been hashed over many times --- i would like to ask you all if it has ever been your experiance that you actually witnessed a lightning strike on a pole, that in your oppinion, the driven ground rod protected the system and provided a positive function?
i have been involved with maybe 15 or so lightning strikes on poles or outside lighting circuits. i have never seen that the ground rod has shunted or carried lightning current away from the system's equipment. it has blown the lighting contactors off the wall, blew the guts out of the outside lighting panel, blown the meter off the wall, and one instance the current jumped onto the elevator's metal raceway and burnt up the controls and also blew the elevator disconnect off the wall.
and in the recent five years that this ground rod issue has been around, i have really looked closely at the wire connections to the ground rod trying to determine if the insulation showed any discoloration or heat damage?? never found any!!! on the other hand the egc's wire show major damage many times. if any one has any comments lets hear from you.
it's nice that we get to sell these ground rods and increase our profits, but i believe the additional and useless(my oppinion) additional green conductor has been the cause of many electricutions. too many people(qualified and unqualified) have depended on the conductor connected to the useless ground rod to provide a return ground path to the source voltage. and the area of street lighting is continually being maintained by totally unqualified people in many areas. i read somewhere we kill about 350 people each year on street light poles in the united states.
looking into many of these cases, the sad thing is nobody learns from these deaths. take the average service truck and employee --- and place him at an accident sene where a car hits and shears off a street light pole at 2:00 A.M. .. he is called to make the pole safe and resplice the conductors to make the rest of the system operational. how does he determine the ground rod wire from the egc and confirm that they are intact? somebody gets sued --- and they forget it!!!
