Customer has a 3Phase 100A subpanel protected by a 3 Phase breaker in the main distribution panel. Voltage is 120/240. Panel is wired with #6 from main breaker abour 20" to the subpanel. Load on each phase is about 28A, all 3 phases are within 28-30A. All loads are florscent lights w/ magnetic ballasts max on each circuit is 6A. So it seems balanced. Problem is that the panel and breakers are overheating. You can feel the excessive heat by touching the panel cover. No breakers are overloaded. Customer wants the panel changed out, before we do, any ideas on what may be causing the problem.
