Recharge 816
- Gulf Breeze ,Florida
- Electrical Contractor
Job has a 400 amp main service with main Breaker with 400 amp breaker panel . The 400 amp service is on a detached garage although it is connected by a covered walk way to the main house. The house has a100 amp panel installed in the utility room which is fed by a 2/3 alum. SE cable,fed from the 400 amp service, the owner want to locate the new generator on the far side of the house due to gas meter close to that area . Would it meet NEC to intercept existing 100 amp panel feed in attic install junction box, install new feed thru attic to far side of house connect to new auto transfer switch then install load off transfer back to existing house panel only ? The generator would only provide power to the house 100 amp panel in the home thru a auto transfer switch. Thank you for you help .
