Jimmy7
- Boston, MA
- Electrician
If you install two 20 amp 120v circuits in conduit that originate from a 120/240 volt service, is that two or four current carrying conductors?
Wouldn't a 1ph MWBC be more likely to have two CCCs?if you're asking about a MWBC odds are you have 3 CCC's
Two hots and two neutrals2 neutrals, 2 hot?
Edit Roger beat me to answer
Definitely four CCCs.Two hots and two neutrals
Doh! You're right Larry.Wouldn't a 1ph MWBC be more likely to have two CCCs?
Since the neutral conductors are a mandatory part of the return path for the current, and always must carry the full current, the neutrals have to count as CCC's.If you install two 20 amp 120v circuits in conduit that originate from a 120/240 volt service, is that two or four current carrying conductors?
If it’s 75 deg wire go off the 75 degree column to derate?Be sure you're starting with a 90 deg conductor and your right
Yes. You start your calculation beginning with the conductors starting temp.If it’s 75 deg wire go off the 75 degree column to derate?
