Need help on rewiring 12 lead Thermoking 15 KW 3 Phase generator?
adula
New member
Rocksprings, TX
Hi,
I ran across this site while searching and saw an old thread on rewiring a 12 lead generator. I rewired the unit in 1999 to supply 3 120 VAC lines, but now need 240 VAC to power our 1 1/2 HP deep well pump. I am confused after reading the old thread. I would like a 240 VAC line and a 120 VAC line. The current configuration is as follows: Leads 10,11, and 12 tied together to the ground buss; Lines 4, 5 , and 6 tied together; Leads 3 and 9 tied together; Leads 2 and 8 tied together, and Leads 1 and 7 tied together, The last set gives me 120 VAC from each pair. Can someone help me with rewiring of the 12 leads? In our last move I lost the Thermoking manuals which had the information.
Thanks,
Alex
George Stolz
Windsor, CO NEC: 2017
Service Manager
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
