I have an existing building with existing electrical service to remain.
Addition will be built, but it will be structurally separated, so there are no steel connections between new and existing.
I am providing new distribution panelboard for the new addition (it is still located within the existing building, but right outside of a new addition) and I am bringing ground and neutral to this panelboard. Per NEC 2002 250.32B the neutral is isolated from the ground bus. There is a grounding electrode (ufer ground) for the new building. There will be water, telephone, gas nad other piping run between the buildings.
The question is : should the steel of the new building be bonded with the existing building steel?
