GG
- Ft.Worth, T.X.
I have a mobile home that needs its service connected. The service disconnect is 25' from the MH. The 200A MBP panel in the MH has the EGC bus and neutral bus seperated, a bonding conductor going to the frame of the MH, and a CWG. At the service disco. outside there is a ground rod. My question is does the MH also need a ground rod or are the CWG and frame all the grounding/bonding that is needed?
