- Tennessee NEC:2017
- Semi-Retired Electrician
I was posed a question concerning getting neutrals mixed up between two panels. The scenario was adding a subpanel adjacent to the main panel. Then moving some circuits from the main over to the sub. What is the danger if you accidentally moved the wrong neutral(s) over to the sub? I couldn't think of any real danger, all I could think of was keeping the grounded, ungrounded, and egc grouped/run together. But, the neutral bars in each panel are tied together by the feeder neutral. Assume PVC was used to feed the conductors through.
