LSOD
New User
- North Little Rock, Arkansas
We are doing a PV installation and want to route our DC feeders (2-3 inch) from Array Combiners to the Inverter via steel columns (10x10x 5/8). A hand hole is available a bottom of column, we will use bushing on top to enter a junction box. Is this permissible? Provide NEC Code articles.
The second piece will be can we mix different system wiring in the column, A/C -D/C if properly identified. Would this be allowed.
We see similar situation at gas station fueling islands, routing of lighting circuits.
Thanks, LSOD:slaphead:
