MCC's inside HVAC Rooms
hajijm
Motor Control Center (MCC) for the AHUs is located inside the Mechanical Room, dose it violate the NEC ?????? or it shall be in adedicated enclosure or in electrical room. please advise.
rhombus65
Re: MCC's inside HVAC Rooms
I wouldn't think that the MCC's are considered service equipment so there should be no problem.
Actually I have seen this set up in the past as long as you have your working clearances.
