does the nec strictly define low voltage as less than 600 volts?
S screwybazooie Guest Sep 25, 2005 #1 does the nec strictly define low voltage as less than 600 volts?
B bphgravity Senior Member Location Florida Sep 25, 2005 #2 Re: low voltage No. In many sections the code separates requirements between 600 Volts, Nomial, or Less, and Over 600 Volts, Nominal, but in no way does the code define under 600 volts as being "low" voltage.
