I was wondering what type of cable you guys use for low volt lighting. For under/over cab lighting we use seagull ambiance, juno track 12, lucifer etc. 12 or 24 volt systems. We generally put the trans in the basement below the kitchen and whip 14/2 or 12/2 low volt wire to each fixture location. In 15 years I have never been knocked down for using this wire. The inspector said it wasnt rated for the use I am using it for.( note I do not disagree with him). He says to use 14/2 or 12/2 romex. My question is what do you guys use for this? Lucifer's system uses crimped ends to connect to the lighting track and you cant crimp solid wire. I have a large kitchen remodel to look at and I am wondering what a "safe" wiring method would be.
