novemberaudi
- boston
I have a job where i have to pipe for various low voltage alarm cables. Just looking for a little advice do I just figure the area of the cables and use 40% conduit fill or is there a better way.
So if you design for the NEC maximum of 360 degrees, you can run -20 feet!In many cases, the NEC does not have rules covering conduit fill for low voltage cables. Many cable manufacturers have instructions that show wire fills of less than 40% and in one case that I know of limits the length of the pull to 100' of straight conduit, deduct 30' for each 90? bend.
I think it is a "CYA" thing on the part of the manufacturer. Like a lot of installers, we ignored the instructions, and made much longer pulls than specified on the supplied information sheet. We did not experience any cable damage issues.So if you design for the NEC maximum of 360 degrees, you can run -20 feet!
Sounds like their wire is pretty weak mechanically. That can happen with small conductors.
